I do not need the fancy features and nice graphics - ONLY reliability. (Maybe I sholud get me a Serato, hehe)
So it is advisable to use the older 4.3 or 5.2.1 to VitualVinyl and the use of timecode Vinyls and the original interfase box from Numark Virtual Vinyl full control package? Nu use of any controllers etc, just pure old Technics 1210's and somtimes CDJ/DVJ1000's
It is not for bedroom toying but serious pro clubbing and crashes will be catastrophic! I'm going for a 100% stability. I do not use effects, video, karaeoke etc. I just play records.
My OS is 10.5.6 but have not updated the OS since install. This Macbook is for the use of VV liveplaying ONLY.
Maybe mr. Skyfxl might know this? Anyone else? :-)
Have a nice day.
Have a nice day.
geposted Mon 23 Feb 09 @ 11:35 am
Hi clubkid,
V5.2.1 is way more stable than the V4.3. U can opt not to use the extra and disable video etc.
Regards;)
Regards;)
geposted Mon 23 Feb 09 @ 12:16 pm
Have a nice day.
Have a nice day.
Howdy we recommend 5.2.1 strongly as this has many improvements.
geposted Mon 23 Feb 09 @ 4:36 pm
for just audio, as long as im not using the recorder, it has been 100% stable. absolutely no problems audio wise. there are some tweaks to make it faster though, ie song loading but it is 100% stable audio wise
geposted Mon 23 Feb 09 @ 5:37 pm
Oki... I tryed the AppDelete but it would'nt work on the 4.3. Where is it the Macbook hides them small files there also have to be deleted after the 4.3, besides the cue-map in dokuments? I think it's in preferances some place; AND what are they called? It is about 2 or 3 files, I guess.
geposted Mon 23 Feb 09 @ 5:53 pm
when you upgrade it should overwrite the file anyway...
and you can use spotlight to find them but there is a file in applications as well as your documents and that should be in. documents - numark cue - and those are all the files
geposted Tue 24 Feb 09 @ 7:37 am
