Heya,
Have looked all over this forum but cant seem to find the answer.
Am trying to set up VDJ so can use my video camera to show images of dancefloor etc. But i am having no uck at all getting any video showing, all it shows is a black screen.
Have got the camera set to webcam mode and connected via the usb.
Any help on how i can set this up to work.
Cheers.
Cheers.
geposted Mon 23 Feb 09 @ 1:21 pm
What type of camera are you using: brand / model
geposted Mon 23 Feb 09 @ 1:38 pm
Its a panasonic NV-GS250.
geposted Mon 23 Feb 09 @ 1:49 pm
First, you're going to probably need to install some pc drivers for that camera. i got a CD with my Sony HC96 DV camera. After you install those drivers....connect your camcorder to a USB port on your laptop. Is will probably want to install more drivers. Once you're done with that. turn on your camera and try to find a stream setting in the menu. this will stream your video signal to your laptop usb connection. with your camera in camera mode...open up MS Movie Maker and make sure you have an image making it to your pc. If you do, then close Movie Maker and open up VDJ. Activate the camera option and you should be good to go!
geposted Mon 23 Feb 09 @ 5:31 pm
is it possible to do this with my camera, it is a Aiptek Pocket DV camera?
geposted Fri 17 Jun 11 @ 11:53 pm
What tab is the camera option in?
Can this be clicked on and off automatically? Let's say I am playing a music video and I transition to an audio only music, will the camera kick back on or click back off when I play a video file kinda like the clipbank option?
geposted Tue 04 Oct 11 @ 11:54 am
es it can be turned off.this camera option is in effects/video effects i think.
geposted Tue 04 Oct 11 @ 1:15 pm
If windows:
o - when you plugin or remove USB camera device, it should go ding-a-ling :) but maybe not
o - goto control panel and select Scanners and Cameras and see if your camera is listed when it's plugged in
o - best to install drivers that came with camera, but with my logitech camera, I just plugged it in and it worked. The only difference was the display camera name will have some generic name like Camera Device or similiar.
o - Does it work outside of VDJ ?
geposted Tue 04 Oct 11 @ 2:22 pm
Thx guys.
Just looked though and in the effects tab, I only have Boom, Boom Auto, Slideshow, and Clipbank as options. Is the camera a plugin I need to dnld, guess I need to look. hahah
I have a Mac. Guess the setting would be a bit different?
geposted Tue 04 Oct 11 @ 3:18 pm
im not sure but i have mac and camera option is not in other/video effects and could not find it in download section.
geposted Wed 05 Oct 11 @ 5:49 am
Yep, I couldn't find it either.
Hopefully someone can shed some light on this. Tried searching and all I can come up with is this thread. so I had to resurrect it. LOL
geposted Wed 05 Oct 11 @ 1:31 pm
i just got my nokia N8 working as a cam via a usb port as it 12mp and 30 fps it quite ideal but not sure what will happen, if someone calls me. lol not tried that out yet
but am looking to get a cam that works well in low light any recomendations ppl
geposted Fri 25 Nov 11 @ 3:55 pm
