hi guys everytime i put my rmx on asio mode and i close it ....when i open it back i find out its gone back to wdm... how can i keep it in asio mode cos i think the asio mode works better?
geposted Mon 23 Feb 09 @ 11:13 pm
Why you want asio mode?
And your version only supports WDM mode i think.
geposted Tue 24 Feb 09 @ 1:43 am
It's the other way around Rune, the RMX edition is fixed in Asio mode. As you know you need the Pro version for the WM option.
There is a simply way of doing this. If you are playing around with the trail version, then set like this
Config>Sound Setup
Input - None
Output - Headphones
Soundcard - DJ Console RMX (Icon)
Apply Eq on External inputs - Check.
By checking this box it puts the RMX in Asio mode anyway. You don't need to use the Asio icon in the soundcard option. And it should keep the RMX in Asio mode
geposted Tue 24 Feb 09 @ 2:26 am
