I've been using the VCM-100 for about 60 days and love it but would like to tweak it.
Anyone using this controller that would like to converse
geposted Tue 24 Feb 09 @ 11:05 am
There is a mapper out..
https://virtualdj.com/addons/4299/VCI-100_MIDI_Mapper.html
This one you can change to fit your own needs.. ;)
Leds wont work when using a mapper like that, but all functions will
geposted Tue 24 Feb 09 @ 11:18 am
VCM or VCI? You wrote VCM twice so I guess that's what you mean, Norway gave you the link for the VCI and I don't think there is one for the VCM.
You are the first VCM user I've come across here so I'm not sure if anyone will relate.
geposted Tue 24 Feb 09 @ 11:28 am
ah.. damn;) my bad..
read VCI-... But I see its VCM now ..
geposted Tue 24 Feb 09 @ 11:33 am
I do use that mapper but it will not let me map it. It only lets me able to use the VCM. It has 4 (F) key button I’d like to map unfortunately cant do without a mapper... everything else works fine.. This has a sound can as well I would like to tweak..
I can’t figure out what to do with the VCI-300
geposted Tue 24 Feb 09 @ 12:18 pm
things might get better soon;)
The VCI-300 isnt supported yet.. and things might improve for next version.
So have a little patience, and I'm sure you life will be easier;)
For now you can map it up manually if it has midi (I dont know the controller you have).
If its midi, its easy to map up as you want..
Choose a feature in VDJ keyboard shortcut settings, and then press or move a part of the controller, to have it mapped
geposted Tue 24 Feb 09 @ 12:28 pm
Thanks but that a bit no go. just tryed mapping a button and nothing happend
geposted Tue 24 Feb 09 @ 12:49 pm
1) Choose ADD
2) Choose a function
3) Press a button on your VCM that you want to use for the function
geposted Tue 24 Feb 09 @ 1:19 pm
The (F1 – F2 – F3 - F4) on the controller are not assigned to either deck. Just one set if F keys. I tried to map it but nothing happens in the KEY window (Midi Note).
These keys would very helpful if I could assign then.
At this point F1 & F3 turns on Loop in on deck 1, F2 & F4 are Loop out
geposted Tue 24 Feb 09 @ 2:57 pm
Do you using the VCM with TCV and the build in sound card ? Is it possible ?
geposted Fri 03 Apr 09 @ 6:59 am
