I just bought Hercules DJ CONSOLE RMX.. can this controller run to the Home theater speakers?? or only for PC Speakers?? I have JBL Home Theater speakers and i want to mix music on those speakers.. is this impossible?? Do I need to buy a power sound cards??
geposted Tue 24 Feb 09 @ 12:58 pm
yea u can all u need is a Rca cables...connect them to the Aux of your amplifier and it should work....:D!!!
Pd your Home theather system amp is the one i was talking about...
geposted Tue 24 Feb 09 @ 1:22 pm
@lov3rboy408
Please could you put your VirtualDJ serial number (the one on the CD sleeve) in the "Modify my profile" tab. It will them show us that you have a lovely RMX and you are a licensed member.
Sonido1902 is right, you need to run a RCA cable from Output 1&2 of the RMX to a Aux or a spare channel of your Amp. Then just select that channel to hear the RMX.
geposted Tue 24 Feb 09 @ 1:54 pm
I'm sorry I don't trust the internet.. i scare people my steal my Serial Number.. this is for my own protection.... Thank you for recommendation.. and also thank you for the help..
geposted Tue 24 Feb 09 @ 1:57 pm
OK and No worries :)
geposted Tue 24 Feb 09 @ 2:04 pm
