hey guyz,
so when i click on the config button for my tcvs, and then i run them, even if the tts r both spinning in the same direction, one of the waveforms moves in the reverse direction,
so if both of my tts spinning clockwise, if i hit play on one tt, the waveform moves forward, but if i hit play on the other deck, the waveform moves backwards,
and i gotta go into the options and click on invert phase,
WHY DOES IT DO THAT ??? and how do i fix it?
i run vdj pro 5.2.1 on vista with ssl tcvs and hercules rmx as a soundcard.
any help is highly appreciated.
geposted Tue 24 Feb 09 @ 1:30 pm
If you have to hit invert phase to get it to play right, it just means you have the RCA cables for that TT the wrong way around
geposted Tue 24 Feb 09 @ 1:38 pm
oh thanks a lot man! i did not even think about that! ur a life saver!
geposted Tue 24 Feb 09 @ 1:39 pm
But that is why the option to Invert Phase is there ... so you don't have to switch the cables back... just check the option and you are good to go.
geposted Tue 24 Feb 09 @ 1:52 pm
i know i can, but i guess i should just switch the cable, want eerything tobe perfect u know..;-)
geposted Tue 24 Feb 09 @ 1:56 pm
As my old man would say
"Son, if you are going to do a job, do it properly in the first place" lol
geposted Tue 24 Feb 09 @ 2:01 pm
haha true dat true dat! ;-P
geposted Tue 24 Feb 09 @ 2:12 pm
by the way, i checked my rca cables, they were fine, what was wrong was on one of the numark groovetool headshells the idiot i bought it from gave me, he switched the 4 cables, thats why it was reversed,
just fyi for anybody using those kinda needles...
geposted Mon 09 Mar 09 @ 7:35 am
