I'm glad you got what you needed, and good luck :)
geposted Mon 16 Mar 09 @ 4:48 am
Would anyone know why some buttons like Reverse, Sync, and pitch will show the state of the button (Down or Selected) when using an external device like the 5500, but other buttons won't?
My buttons work fine ON SCREEN, but so far, I can't see the reaction (States of the button) for Brake, Bake Spin, skip & Pitch bend... etc.
Play and cue only show the selected state when using an external device. I'd like to see all the states of the buttons when using an external device.
I'm Wondering if there is code missing?\
Also, is there away to show which deck is selected by using the layer button on the 5500?
I can select the left or right deck with the layer button, but it doesn't show me on the screen unless I hit the tab key.
geposted Tue 17 Mar 09 @ 2:45 am
