hi all,
Just wondering if anyone might know what the problem is?
Now on my 3rd laptop having brought a better spec and back to windows XP.
I have the RMX console with the 5.2 vitual dj upgrade but I noticed a very slight crackle noise on the crossfader, I thought it was dirt so blew it out but noticed it would make the noise even when moving the crossfader with the mouse,this also happens with the other sliders/knobs.
Any suggestions gladly received.
Thanks Van
Thanks Van
geposted Tue 24 Feb 09 @ 8:06 pm
Try these settings
geposted Tue 24 Feb 09 @ 8:16 pm
hi,
thanks for the suggestion,
Just solved the problem 4.00am but just glad to get it working.
I applied :
eq to the outputs which got rid of the crackle then I got major stuttering , then I remembered a thread on here about turning of the LAN Wifi which then got rid of the stutter. Have been on it for 2 hours without a glitch so I am well happy.
I now like computers. lol
I applied :
geposted Tue 24 Feb 09 @ 10:26 pm
The above settings or set-up cannot be accessed by a LE version...just for additional info.
Good you got it solve m8t.
geposted Wed 25 Feb 09 @ 1:31 am
