Forum: Old versions
Topic: Latency Checker (Look at the top please)
guys.. i still dont know how to use that latency checker.. i ran it on my computer and i saw a few reds...but i could not figure out which driver was causing the issue.. is there a more specific way to use the thing;..it seems to have helped a lot of people
geposted Tue 24 Feb 09 @ 9:23 pm
The DPC latency is quite a simple tool to use.
This is what I did to set my gig Vista laptop up. I opened up device manager and then the Checker, so both were on my screen.
In Device manager I started to disable the device's that we know can cause audio glitches and problems, one by one. Started with the Wifi/Bluetooth adapters. Disabled that, then ran the checker for a few minutes to see the results, Then disable my integrated webcam, then ran the checker again, Disabled the internal modem, then did the check again, and so on.
Every time I disable a device the results were getting better. I ended up disabling 6 devices I think, till I was happy with my Latency results and I was getting mainly green, with the occasional yellow spikes.
So remember, disable one device, then check, disable one device then check and so on.
Hope that helps.
