hey all was wondering if either of these Pioneer cdjs would map up with virtual dj or if they could be run with the software.....if so what do i need.....also id like to know what i can hook up to my mixer to record some of my mixes
geposted Tue 24 Feb 09 @ 10:02 pm
Yes, the 800's or 1000's work perfectly with a external 4 in 4 out soundcard. You need to download the TCCD timecode in the download section, burn onto a blank cd and make the necessary connections with rca's to the external sound card. There you go, a perfect system that rocks!
Syberman
Syberman
geposted Tue 24 Feb 09 @ 11:14 pm
cool thanx so i put put that software on the cds and put the cd in the cdj's right???
geposted Wed 25 Feb 09 @ 10:02 am
Actually, what you have to burn on a CD is this -> http://fr.virtualdj.com/products/timecode/cd.html <-
A timecode signal, choose the "Pro Grade Sound Level" ;-)
geposted Wed 25 Feb 09 @ 10:05 am
I believe all future CDJ products will feature midi and have the sound device enabled, just as the CDJ-400.
This allows for full control, full customisation (control layout) and takes away the need of having a separate high end soundcard.
The CD drive becomes a solid back-up device, rather than running a timecode which is far more sensitive than using a midi device.
The cheaper iCDX also feature midi and USB control.
The CDJ800/1000 are the better option for scratching though.
geposted Wed 25 Feb 09 @ 10:25 am
Take a look at the new denon 3700 - also with midi .
geposted Wed 25 Feb 09 @ 1:06 pm
That's right. Just insert into the cdj's and play! What external soundcard are you using?
Syberman
geposted Wed 25 Feb 09 @ 1:36 pm
maya44 is the soundcard im using......which brings me to another question what sound card can i buy that has more then 4 in's and 4 outs b/c i want to be able to use that sampler within vdj on one of the channels
geposted Wed 25 Feb 09 @ 6:56 pm
Yeah if your looking at buying CD decks, then I would get the Denon DNS 3700. Such a brilliant deck!
geposted Wed 25 Feb 09 @ 7:33 pm
yea they look awesome saw the demo....lots of stuff you can do with them
geposted Thu 26 Feb 09 @ 8:42 pm
bewarned with Denon DNS3700 - bad reviews when used with Mac aparently, review in this months DJ MAG (UK).
Of course if your a windows user - go for it - i want 2 of these babies!! lol
geposted Thu 26 Feb 09 @ 8:44 pm
not planning on using a mac ever there nice but my next comp im going to try and buy is going 2 be a sony viao and hopefully i can get xp installed on there as well.....hey i was also wondering what do i need to b able to record out of my mixer
geposted Sat 28 Feb 09 @ 10:33 pm
Pioneer CDJs rule.. I have the CDJ 1000mk3s. You dont really need midi when you have all your functions on the keyboard short cuts. When it comes to table table top CD decks... I would stay away from Denon. Pioneers can take a beating that denons can't. That's why you see them in almost all the clubs.
geposted Sun 01 Mar 09 @ 2:06 am
yeah man those mk3 1000s are a fortune though lol would love to have them think im going to go with the 800s though my friend has a pair and there nice i like them alot......but hey does any1 know what i need to be able to record mixes out of my mixer
geposted Mon 02 Mar 09 @ 1:35 pm
As CDJ 400's don't work with VDJ on Mac, could I get them to work by using a 4 channel external sound card like with the 1000's?
geposted Thu 19 Mar 09 @ 6:33 pm
The CDJ 800s are really good. Running them with DJ software, you don't need the 1000's.
geposted Fri 20 Mar 09 @ 1:19 am
