why?
geposted Wed 25 Feb 09 @ 11:21 pm
from looking at previous threads from yourself you are a Mac user?
If so you need to set some permissions within Finder so that Virtual DJ can "write" to the database.
If you go to /Users/xxxxx/Documents/VirtualDJ/VirtualDJ Databaase v5.xml and go to "more info" - at the bottom of this screen is Sharing and Permissions - make sure they are all set the Read & Write.
You will need to repeat this for a any external harddrives you have as there will be a database file on each. Once done everything you do within browser should be saved.
Hope that helps.
In future you may get a quicker response if you put this in the Mac Tech Problems forum or at least let people know what system you are using.
Thanks
Hope that helps.
Thanks
geposted Thu 26 Feb 09 @ 2:38 am
thanks
geposted Thu 26 Feb 09 @ 10:45 am
