Support suggested I post a topic asking if anyone has found a way to map the touch pad on the nanoPAD with the TK Filter V2 effect? I can map the sliders from all the other effects, but it does not work for this effect.
Any ideas or is the author of that effect here to indicate which MIDI control/value it may be?
I know there are external effects processors out there, but I am wanting to go this route as you can do loops and samples as well on the one device.
Thanks!
Chad
Thanks!
Chad
geposted Thu 26 Feb 09 @ 9:14 am
