Forum: Old versions
Topic: Herculess DJC MK2 Error
Hi guys
I am using Herculess DJC MK2 many years. But now the console is not working anymore. When I plug it in the buttons are shining but neither the PC recognises a new device nor the dj softweare recognizes it.
Got the same porblen on my Apple Power Book longer time ago.
I do not now waht is wrong? Perhaps there was an error during firmware Update.
Thank you very much
PC:
OS: Win XP XP2
Athlon XP 2100+8 (1.7 GB)
512 MB DDR Ram
geposted Thu 26 Feb 09 @ 12:17 pm
Ive got the same problem! anyone with a solution? im using a DELL Latitude 620
Can you define the problem a little bit?
Did you just buy the console or was it installed on this computer previously?
If it was previously working, what happened between the moment it was and now ?
If this is your first installation, did you noticed any error messages during the installation process?
Did you try the latest driver (4.HDJS.2009)?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=177&cid=1
Hi Phatso, im guessing ive got the same problem as roop, a long time ago i disconnected my mk2 from a firmware upgrade, since then the console is not being recognized, in any way, by windows even tho the lights turn on (and stay on), I even tried in different computers and the manual firmware upgrade unsuccessfully since the device is simply not recognized by the system.
Any ideas?
DV
Yes, exactly. I didnt really manage to do it since the console is not recognized when i plug it in...
Hello cipo86,
Are you sure you have kept pushing down the talk-over button while connecting the USB plug?
hi MIB yes I have, doestn make any difference :(
