Hello everybody, anyone knows if any of the following softwares, Adeona or Lojack, interfere with the virtual dj?
In the last week, someone stole my new notebook, now I think, I would buy another and install any software for recovery in case of theft, I am very interested in installing Adeona.
thank you very much.
geposted Thu 26 Feb 09 @ 1:51 pm
Just I would like to know if somebody have any problems with this kine of software's and Virtual Dj?
Thanks
geposted Fri 27 Feb 09 @ 10:22 am
problem is if someone streals your laptop they will probable wipe it clean
geposted Fri 27 Feb 09 @ 12:17 pm
Please, I just want to know if anyone has experience with this type of software.
Anyone know if ADEONA has any conflicts with the operation of VDJ?
I want to know before making a decision to install it on my laptop.
Thank you!
geposted Fri 27 Feb 09 @ 1:45 pm
i was saying software like that doesnt work so there is no point in installing it weither or not it works with vdj
geposted Fri 27 Feb 09 @ 2:06 pm
It might work if you dont set a password on your system. Give a thief a better option to not wipe the system. I believe Lojack depending on the brand of system has BIOS support to reinstall the software back on the drive if the drive is wiped clean. I have an option in my BIOS to enable it, but its not free. Also I would not think it would interfere like any other program unless it decides to use up a large amount of CPU or memory resources.
-David
-David
geposted Fri 27 Feb 09 @ 3:01 pm
Thanks for the info, I install Adeona ready and nothing bad happens to the virtual dj, so far so good, I will keep them informed if something unusual happens, I appreciate your support, thank you.
geposted Wed 04 Mar 09 @ 9:23 am
