I hear a terrible noice, no mather if the music is playing or not. It stops when I reconnect the USB-plug from the HDJC, so it's over without power connection. The amplifier is okay. I think this is not a VDJ problem but caused by HDJC. Does anyone have a solution? Thanks!
geposted Thu 03 Mar 05 @ 2:45 pm
i hade the same problem -You need a "Ground lifter"
go to at store that sells car audio stuff... a small box with stereo input /output rca connector ,about 20 Euro (a line transformer)
geposted Fri 04 Mar 05 @ 10:15 am
Thanks, I'll try. Another cause could be the power via the USB connection of the PC. Maybe a USB hub with its own power supply is a solution.
geposted Fri 04 Mar 05 @ 3:18 pm
