i have some video dics that are not promo only and need to rip, what program can i use to rip them into vob files?
geposted Sun 01 Mar 09 @ 9:32 pm
DVD decrypter
www.doom9.org
www.doom9.org
geposted Sun 01 Mar 09 @ 10:16 pm
VJ Ripper
geposted Mon 02 Mar 09 @ 2:22 am
ImTooDVDRipper Platinum
geposted Mon 02 Mar 09 @ 4:24 am
this may help you bgotti or not, one way or the other. there are many rippers out there used by members of these forums who have different success rates with them and claims to how easy they are with the user and you all know the brands that get mentioned more than others
the software i'm going to show you is found at http://www.avsmedia.com/VideoTools/index.aspx and is on special at $39.95 or roughly £20 as well as ripping it will record from and too any number of file formats, you have everything you need in one package and comes in a "try before you buy version", no need to read through lines of endless instructions take a look at the video clip and see how easy & quick it is...
this is the one i've always used and think it's quite easy and quick, would like to hear comments from anyone who use other software about their comparisons with it, is the software you use quicker, faster or anything else you want to add, maybes i should dump mine and go with something else.
it took less than four minutes from me starting to make this video to the end to rip and tag two DVD music video tunes
n.b those prices and the tutorial i did are from over a year ago, so you have to check out their curent prices.
geposted Mon 02 Mar 09 @ 5:22 am
thanks for the help everyone! im going to check them all out.
geposted Mon 02 Mar 09 @ 10:49 am
k
geposted Mon 02 Mar 09 @ 11:30 am
