Hi guys, Goochie here, newbie to site,
Have read thru lots of forums but cant find the simple answers to my questions.
1. Does VDj work ok with a DAC2 ?
2. If not do I have to download any mapping stuff?
i am currently using PCDJ Red + dac 2, not happy with PCDJ and have had VDJ highly recommended so considering changing software.
Any help greatly appreciated, specialy as I'm sure youv'e all seen this question many times before (did search forums, couldnt find it)
Many thanks
Goochie
Many thanks
Goochie
geposted Mon 02 Mar 09 @ 2:05 pm
The PCDJ DAC2 has native support within VirtualDJ.
Once connect all you have to do is activate it in the remote control tab of the config. There is no need to download any mapper. Unless you want to change the default settings of the controller, then I believe there is a mapper available.
It's just plug and play.
Hope that helps you decide.
geposted Mon 02 Mar 09 @ 2:53 pm
Many thanks for that, will download free trail of VDJ and have a play.
Many many thanks.
Goochie.
Many many thanks.
Goochie.
geposted Mon 02 Mar 09 @ 3:30 pm
