I reinstalled my OS, so i had to reinstall the rmx drivers, which i did. I get an asio erro when i run in that mode, and when i setup the rmx console option, everything works except the jog wheels any ideas? Also it seems the scratch button is not work, i cant use it to change between scanning and scratching.
geposted Mon 02 Mar 09 @ 2:23 pm
Which mode do you want to use your RMX in WDM or Asio
To get the RMX to run in WDM mode try this
Config>Sound Setup
Input - None
Output - Headphones
Soundcard - DJ Console RMX Icon
Apply EQ on external inputs - Unchecked
I use the above setting on my RMX.
To get the RMX to run in Asio mode try this
Input - None
Output - Headphones
Apply EQ on external inputs - Checked
Try one of these sets settings and I think your RMX will run correctly.
Config>Sound Setup
Input - None
Output - Headphones
Input - None
Output - Headphones
geposted Mon 02 Mar 09 @ 2:45 pm
I have tried both modes, everything seems to be working except the jog wheels, and the up and down arrows. All other controls seem to operate normally.
CORRECTION
The jog wheel seems to work in scratch mode before the song is started, once the song is started i can not do anything with the wheels
CORRECTION
geposted Mon 02 Mar 09 @ 3:05 pm
Weird, i had to remove the rmx.dll from the moramax mapper. Now all is fine.
Not sure i understand that..thanks for your assistance Jimmy
geposted Mon 02 Mar 09 @ 8:05 pm
No worries mate. I was going to ask you whether you was using the mapper, but I had to go to bed early.
Glad you are sorted though.
geposted Tue 03 Mar 09 @ 12:25 am
