is there a way to sync the volume...i know that not all songs are recorded at the same volume but is there a feature that will sync the volume pretty close
or any software that will analyze the music and set it equally
geposted Mon 02 Mar 09 @ 10:09 pm
an alternative software solution is winamp... its an audio player w/ many useful plugins. I'm pretty sure a standard plugin is for automatic music normalization which is what you're after.
in VDJ look in config-->options and turn on auto gain. it matches the volume. be sure towatch your levels.
geposted Mon 02 Mar 09 @ 11:09 pm
vdj had that feature before up until 5.06 (i think), i like to see it come back but for now i use Mp3 Gain to at least normalize the volumes.
i have mine set @ 94db, so no distortion on mp3's.
http://mp3gain.sourceforge.net/download.php
geposted Tue 03 Mar 09 @ 6:45 am
