Hi everyone!
In newbie terms, can someone tell me how to setup video mixing on my macbook pro? I have the latest MacBook Pro and i use VDJ with Hercules MK2 controller. How exactly, can i pipe the video out of my macbook? Is there a setting somewhere? Do i need a new controller?
:D
:D
geposted Tue 03 Mar 09 @ 10:32 am
You will need an adapter - if your using a new late 2008 Macbook it will be a Mini DisplayPort to DVI or to VGA.
Once connected and you can see your desktop on your 2nd screen go into CONFIG ----> VIDEO
Under TV Output - in the drop down menu select you gaphics card - in this case Nvidia then click activate.
That should do you.
That should do you.
geposted Tue 03 Mar 09 @ 12:45 pm
