ANOTHER DJ IN THE AREA PURCHASED A COPY OF VIRTUAL VINYL AND HAS SINCE THEN MOVED TO SERRATO. WILL I HAVE ANY PROBLEMS WITH DOWNLOADING THE USED SOFTWARE? WILL I NEED ANY CODES? WHAT ARE THE DISADVANTAGES OF BUYING A USED COPY?
FOR THOSE THAT ARE USING NUMARKS VIRTUAL VINYL,....ANY COMMENTS, PRAISES, ETC????
geposted Tue 03 Mar 09 @ 6:49 pm
I'm sorry to inform you, part of the EULA (End User License Agreement) is the license is not transferable. That is the bad news. The good news is, if he did not register the software here you should be OK.
geposted Tue 03 Mar 09 @ 8:23 pm
from feloops: ANOTHER DJ IN THE AREA PURCHASED A COPY OF VIRTUAL VINYL AND HAS SINCE THEN MOVED TO SERRATO. WILL I HAVE ANY PROBLEMS WITH DOWNLOADING THE USED SOFTWARE? WILL I NEED ANY CODES? WHAT ARE THE DISADVANTAGES OF BUYING A USED COPY?
from TearEmUp: I'm sorry to inform you, part of the EULA (End User License Agreement) is the license is not transferable. That is the bad news. The good news is, if he did not register the software here you should be OK.
I'm sort of in the same situation. I just purchased a Used Vitrual Vinyl package that contains CUE, the two vinyls, two CD's, Total Control, etc. I also already own Vitual DJ Pro. Am I correct in that Virtual DJ pro will work as my software solution to run the Time Code?
geposted Mon 09 Mar 09 @ 1:11 pm
Yes, VDJ and CUE are virtually, no pun intended, the same program...
geposted Mon 09 Mar 09 @ 2:40 pm
