Ok so I Have The New Mabook 2.4Ghz with 2 Giga ddr3 ram and the Nvidia9400, also the NI Audio 4 DJ and a pair of CDJ400.
The idea is to play Audio and video in my set. But as we all know time code and midi control for my CDJ400 is no good in the mac version,
So, which solution is better:
Bootcamp Or Parallels?
THanks
Omry
THanks
Omry
geposted Thu 05 Mar 09 @ 1:56 pm
Bootcamp!!
The reason for this is when you run in Bootcamp, Windows is able to use all the resources of your Mac.
However in Parallels because it runs within OSX it is sharing the resources.
Hope that helps - and please register your serial number.
geposted Thu 05 Mar 09 @ 3:55 pm
ok i understand, just one last question
isnt there nothing to do about the timecode problem in the mac version?!
i know the midi thing will be solved in the next version but is the timecode fixable ot do i have to wait too?
geposted Thu 05 Mar 09 @ 6:47 pm
whats wrong with the timecode? works fine for me, got 2 cd turntables, etc
geposted Thu 05 Mar 09 @ 8:21 pm
I Got the Audio 4 dj (Native instruments), installed it both om mac and on pc, in pc worked just fine. on mac i get no signal in the timecode config (but in the audio preferences of my mac i can see ithere is a signal coming in).
and suggestions? "audio 4 dj" is exactly like "audio 8 dj".
geposted Fri 06 Mar 09 @ 1:36 am
Atm the vv box, maya44usb and the herc do good and does the job when using timescode on mac osx. For normal usage, the audio4 can be just fine without the use of timescode. Just remember to add it as an aggregate device.
Also perhaps u have the older release of the mac version, if so pls register ur serial and get the recent and stable release.
Regards;)
Regards;)
geposted Fri 06 Mar 09 @ 5:53 pm
