Forum: Old versions
Topic: iTunes Library, Using VOB Videos also, help please
I'm jumping ship from Torq and need some quick help please. I've got a gig tomorrow nightand I'd love to use this software. I'm already at the user level I was with Torq...
How does VDJ handle my music library? With Torq's seach tool being rediculously slow, I just use iTunes to search, then open the folder containing the song, then drag to a deck. How does VDJ handle my iTunes library & playlists?
And since I'm now ripping DVDs as VOB files; and iTunes does NOT support VOBs, how can I use these different formats together in VDJ? Thank you!
geposted Fri 06 Mar 09 @ 8:45 pm
VDJ will have a shortcut in the browser in order to access iTunes Music. alternatively if you locate the folders containing your music via the Browser and (right) click and "add to database" then simply typing in the search box will find your files
The same for your VOB's - tell VDJ where they are - "add to database" and there you are - they will work.
