I would want to know if someone has resolved like connecting itself through broadcast, I have shaped following the present instructions in the forum, but when I open winamp and I type address, goes in Time out and it is not connected. Someone that can help me. Thanks
geposted Mon 09 Mar 09 @ 2:26 pm
Are you behind a firewall?
And are you using the adress VDJ gives you under the broadcast button?'
http://your.ip./virtualdj.mp3
geposted Mon 09 Mar 09 @ 2:33 pm
I have opened like instructions door 8000 or in the firewall of windows and in the router (port forwarding), but when I try to open address, (real) http://djtony.no-ip.org/VirtualDJ.mp3 or http://93.65.77.81/VirtualDJ.mp3.. in winamp test to connect itself then but from the timeout. P.S.: I have tried also the visibility address and of the door and externally turns out visible. thanks
geposted Mon 09 Mar 09 @ 3:32 pm
toc toc... nothing ?
geposted Thu 12 Mar 09 @ 5:50 am
