Will virtual dj read MPEG2 files??
geposted Mon 09 Mar 09 @ 11:49 pm
Yes it will
Thank you!!
geposted Mon 09 Mar 09 @ 11:51 pm
I just tryed the MPEG2 file and I get no sound, but the video works fine..do I need to change anything??
And I did check the faders and they are up and the crossfader in the correct position.
Thanks Bob
Thanks Bob
geposted Tue 10 Mar 09 @ 1:10 pm
It may sound silly (and i'm not trying to teach you to suck eggs) but please check the faders are up and the crossfader in the correct position.
You should not need to change anything to get these to work.
geposted Tue 10 Mar 09 @ 1:12 pm
yes I did check the faders and they are up and the crossfader in the correct position. thanks for trying..
geposted Tue 10 Mar 09 @ 1:19 pm
If the audio plays correctly in a normal software (Windows Media Player/Quicktime etc) it should be fine.
But you could try changing the codec in the config menu to Windows Media Video?
geposted Tue 10 Mar 09 @ 1:21 pm
I tryed that code still no sound...the video is fine.. thanks
geposted Tue 10 Mar 09 @ 1:38 pm
does just playing mp3s work ok if not...
check your settings in config > sound set up
geposted Tue 10 Mar 09 @ 3:18 pm
