I am having problems with the quality of my logo because I am using a jpeg format. What is the best format to use the show logo option?
DJ Angel S
DJ Angel S
geposted Tue 10 Mar 09 @ 1:36 pm
jpeg should be fine i would think - just make sure you arent using a low resolution image.
geposted Tue 10 Mar 09 @ 1:38 pm
PNG should be best.. If its supported
geposted Tue 10 Mar 09 @ 3:22 pm
yes png is the best & supported
geposted Tue 10 Mar 09 @ 4:53 pm
Need a little help here. When I try and load my logo it says "Unable to load file" I try different versions JPEG, PNG etc etc same things Could it be the size any help would be great.
geposted Sun 31 May 09 @ 8:41 pm
