i tried updating hercules mk2 firmware but it doesnt wants to update can anyone help me?
geposted Tue 10 Mar 09 @ 6:31 pm
Proceed as follow:
1- Disconnect the Console.
2- Shutdown the system. (Restart will not do, make sure to completely shut it down)
3- Turn it back on.
4- Once completely restarted, click Start> Run> type in TASKMGR then click ok.
Go on the Processes tab and locate the HDJ2CPL.exe. Right-click it and choose END PROCESS then click Yes on the warning message.
5- Click Start, Run and copy the phrase bellow:
"c:\Program Files\Hercules\Audio\DJ Console Series\Mk2\updater\hdj2updater.exe" -manual
6- While pushing and holding the Talkover button (Microphone volume knob) , reconnect the console to the USB. Be sure to hold the button for about 15 Sec once the console has been connected.
7- Now the DJ Console Mk2 Updater Firmware Audio should say BOOT. Click the Open Audio... button and select the filel HDJ_TUSB.dja .Then click Open.
8- Make sure there is a check mark under FLASH for the Firmware Audio and press update!
***DO NOT UNPLUG THE CONSOLE DURING THIS PROCEDURE****
9- Once the process is completed, you will be asked to unplug the DJ Console and plug it back.
10- Close the manual Updater , go to Windows Control Panel, and click on the Hercules DJ Series icon.
In the ABOUT tab, check if the firmware is now installed properly.
3- Turn it back on.
geposted Wed 11 Mar 09 @ 11:36 am
im having the same prob i think...it says windows found driver software...but there was an error when doing so... it says a service instalation section in this INF is invalid.......helllllllllppppppppppp......
geposted Tue 06 Oct 09 @ 11:39 am
