Has anyone seen skins that work for a laptop where its optimal resolution is 1366 x 768? I have a new HP G60 16" laptop with full 16:9 aspect ratio. Its native resolution is 1366 x 768. I have looked through all the skins and have not seen any that match that resolution. Seems like all are at a 1280 x768 resolution. That seems resolution looks real crappy on my laptop (at least for everything else... cue looks okay I guess.)
So short term I set my resolution for normal laptop operations at 1366x768, but when i want to use Cue I use a skin I can maximize to the full screen. So far just the wide screen skins seem to be decent enough, but I still get the warning when I start Cue "you are using a skin with higher resolution than you current resolution."
Any thoughts, tips or skins in the works?
Thanks!
Thanks!
geposted Tue 10 Mar 09 @ 11:08 pm
You need the skin resizer. It's in the Download section.
geposted Fri 13 Mar 09 @ 9:47 am
Yes, sorry meant to post back. I discovered it and it works fantastic. I am trying to pay for the full version, but pay pal was not cooperating the night I tried. I will give it another whirl. BEST THING EVER for VDJ/Cue!
geposted Fri 13 Mar 09 @ 7:35 pm
