I use macbook, vdj pro and mk2. When I anylyse my mp3's and make playlists everything seems ok..... until I restart the VDJ. The memory is erased and I have to re-analyse etc... Anyone? And does anyone know where I can find a mapper for mk2 for mac?
geposted Wed 11 Mar 09 @ 5:30 pm
U have to do that when u using leopard osx.
geposted Thu 12 Mar 09 @ 4:44 pm
I use Tiger. The solution above solves the problem with bpm, but not the playlist problem. They still disappear...
geposted Sun 15 Mar 09 @ 5:59 pm
You need to repeat the steps for any external drives etc etc
Anywhere the VDJ accesses will need read and write attributes.
geposted Mon 16 Mar 09 @ 4:00 am
Delete the preferences files which is located as below.
/Users/yourname/Library/Preferences/com.atomixproductions.virtualdj.plist
Hope this helps;)
Hope this helps;)
geposted Mon 16 Mar 09 @ 10:42 pm
