I currently use a MAYA 44 USB sound card.. is there any BETTER sound card with less latency? or is the maya the one to keep using? I need 4 inputs and 4 outputs since I use time code with CDs and I need it to be able to fit in my coffin as the maya 44 does...
Thanks..
Thanks..
geposted Wed 11 Mar 09 @ 11:11 pm
M Audio Conectiv is what you need.... $249 very good for the price.
Output is loud and clear plus latency is very low (but then again this depends on how fast your computer is).
geposted Thu 12 Mar 09 @ 10:32 am
I second that DJPR1!
Syberman
Syberman
geposted Thu 12 Mar 09 @ 9:57 pm
