Hey guys need help help quick!!!
I created a play list using home PC but when I hook up external drive to laptop, which I now use for gigs, play list is not saved. Is there any way I can get play list on the laptop without re-creating it?
geposted Sat 14 Mar 09 @ 2:36 pm
Problem solved. If this ever happens to you, here is is the fix.
Go to play list on the PC, right click on the desired play list, select copy to, and move your file to a flash drive. Plug flash drive into laptop and go to my computer in virtual dj. Open the flash drive and right click on play list then select move to, then you should be able to move it to the laptop Play list folder. Phew!! I thought I would have to re-create every thing with a few hours to go!
geposted Sat 14 Mar 09 @ 5:18 pm
