Hey gents, was wondering about mapping keys on my MKII. I'm not a pro user so I may be pissin' in the wind but...
I would like to change the pich bend keys, which I never use, to loop in and loop out on each deck.
If this is possible I would appreciate some direction.
geposted Sun 15 Mar 09 @ 9:52 pm
I know my license doesn't allow me to download mappers and all the extra goodies and it's all good cuz I don't really use them.
I was curious if this could be done with the editing of an xml file or something. I don't know if the limitation is within the LE software and the file cannot be modified or if the limitation is that I can't download a groovey cool mapper to make this happen more easily.
I'm hoping maybe one of you can educate me to the limitation I may be facing or what I need to do if this IS possible.
Thanks gang.
Thanks gang.
geposted Mon 16 Mar 09 @ 3:00 pm
You can't change the mapping without using and remapping the MK2 as a MIDI device. However, since you only use the Limited Edition - this is not possible either because the controller is recognized and mapped at startup. However as you have already recognized that as a Pro user this would be possible.
geposted Tue 17 Mar 09 @ 8:15 am
thanks cstoll
looks like I may have to go pro
as my skills have improved I've begun to realize the limitations of the Limited Edition. (thus the designation)
thanks again cstoll
thanks again cstoll
geposted Tue 17 Mar 09 @ 9:10 am
One thing you might find as a Pro - is there is a simple mapper tool that will help you in doing what you ask.
geposted Tue 17 Mar 09 @ 9:14 am
