Hi, I want to buy the software. I'd like to know if the last version of VirtualDJ Pro is compatible with a MacMini G4.
Thank You
Thank You
geposted Mon 16 Mar 09 @ 10:13 am
I would suggest checking the spec requirements yourself compared to what you mac mini has - until a confirmed answer comes your way.
geposted Thu 19 Mar 09 @ 5:47 am
VirtualDJ for the MAC is intended to be used with OS X and preferably with Leopard and the latest series (Intel based) MACs.
There are those that have had success with the G4 series and earlier OS's.
geposted Thu 19 Mar 09 @ 7:56 am
Hi zetabeta;
This are the recommended system requirement on mac.
Mac OSX 10.4.7 or higher
Mac/Intel Core Duo 2.0 GHz or higher
1 GB RAM of higher
200 MB free on the hard-driver
Minimum system requirements on mac.
Mac OSX 10.4 or higher
G4 1.5 GHz or Intel Core Duo 1.6GHz
512MB RAM
Regards;)
1 GB RAM of higher
512MB RAM
Regards;)
geposted Thu 19 Mar 09 @ 11:46 am
