Hey all,
i currently own an ESI u46DJ soundcard but need another for a second setup/replace the serato box which i've never gotten to work properly with vdj
what is better between the audio 8 and the u46 XL? obviously the u46 has an extra set of outputs for a 3rd channel sampler etc... but at the same time it seems the audio8 has superior build quality? or just a fatty price tag... i don't know.
does the maya44 (only $100!) compare to these? which is known to be the most stable/friendly to use etc?
thanks for the help!
geposted Mon 16 Mar 09 @ 2:28 pm
From what I have read the audio 8 can be fiddly to setup in other apps.
The maya 44 generally is very easy to setup.
geposted Sun 22 Mar 09 @ 12:35 pm
The u46 is in the same time tested category as the maya, if you are chosing between just those two.
geposted Sun 22 Mar 09 @ 2:25 pm
