Something is wrong
I play any song and it seems to stick every now and then
almost like a cd skipping
I was messing with the settings but everything looks to be be back to normal
what could it be
what could it be
geposted Mon 16 Mar 09 @ 8:26 pm
the software just shut crashed
geposted Mon 16 Mar 09 @ 8:29 pm
how do i get the crash report
geposted Mon 16 Mar 09 @ 8:30 pm
C:My Documents/VirtualDJ/Crashgard reoprt.txt try looking in that directory.....
geposted Mon 16 Mar 09 @ 8:34 pm
Crash ID=004288dc (date=903090919, version=5.2.1 Pro, build=521, thread=Main, dump=8b086a00, excode=c0000005 (0,0))
Crash ID=004808dd (date=903162028, version=5.2.1 Pro, build=521, thread=Main, dump=83780801, excode=c0000005 (0,73756f50))
this is what i found can anybody help me out
geposted Mon 16 Mar 09 @ 8:38 pm
This is my laptop specs
# Sony VAIO VGN-FW139E/H Core 2 Duo 2.26 GHz 16.4-inch Widescreen Notebook
# General Features:
# Titanium gray color
# Magnesium alloy casing
# Microsoft Vista Home Premium pre-installed w/COA
# Intel Core 2 Duo Processor P8400
# 2.26 GHz CPU speed
# 3 GB DDR2 RAM (4 GB maximum)
# 250 GB hard drive
# DVD±RW DL drive
# ATi Mobility Radeon HD 3470 w/1530 MB Total Available Graphics Memory
# Dolby Sound Room audio
# Built-in 1.3 megapixel MOTION EYE camera and microphone
# Integrated Stereo A2DP Bluetooth Wireless Technology
# V.92/V.90 modem
# 10Base-T/100Base-TX Ethernet
# Atheros 802.11 b/g/n Wireless Network Connection
# Secure Digital (SD) memory card slot
# Memory Stick Duo slot with MagicGate functionality
# 16.4-inch Widescreen WXGA LCD display with XBRITE-ECO Technology (1600 x 900 resolutions)
# 16:9 aspect ratio
# Keyboard with Electro-Static touchpad
# Action buttons: S1, DVD Play, A/V Mode, Volume -/+, Play/Pause/Stop, WLAN/Bluetooth on/off
# Energy Star compliant
# General Features:
# 250 GB hard drive
# DVD±RW DL drive
# V.92/V.90 modem
# 16:9 aspect ratio
geposted Mon 16 Mar 09 @ 8:41 pm
anybody
any ideas
re-install??????
any ideas
re-install??????
geposted Mon 16 Mar 09 @ 9:17 pm
Please be patient Juan....CEL is the best at reading the crashgaurd reports....it might take a bit for him to get back to you.....
geposted Mon 16 Mar 09 @ 10:15 pm
How often do you use the Fix, Check, and Clean on your databases?
Did you recently add any new files or folders to your collection that have foreign characters in the name of the file/folder?
geposted Tue 17 Mar 09 @ 8:08 am
yea i added some new files to my database
fix,check and clean you mean from microsoft or does VDJ have one
geposted Tue 17 Mar 09 @ 2:33 pm
In VirtualDj go into Config->Browser
On the bottom you will see a section for Database with Check - Clean - Fix buttons.
geposted Tue 17 Mar 09 @ 3:11 pm
thanks
how do you know when its done checking does it take a long time
i cleaned and fixed the files but am still having the same problem
just scanned for viruses nothing was found
I tried playing a song off my desktop and still had the same problem
geposted Tue 17 Mar 09 @ 3:14 pm
On the Info tab in the there is a Reset to Default Settings. You can start there and reconfigure VirtualDJ.
What soundcard are you using? The Mk2 or something else? Did you by chance change the Performance settings? If so, make sure Latency is Auto, Safemode and Overclock are UNCHECKED.
geposted Tue 17 Mar 09 @ 8:15 pm
am using the MKII soundcard...could it be bad already????
shut it down and did what you said they were checked .........................but music is still getting stuck it will keep playing but it hesitates
geposted Tue 17 Mar 09 @ 8:22 pm
Have you the latest drivers from Hercules?
geposted Tue 17 Mar 09 @ 8:25 pm
i think its when I have the internet connection on...........but I have been on the net and on VDJ since I bought this laptop with no problems....so i never thought it could be this
when i turn my WI FI on and off I hear the stuttering......man i hope this is the problem
geposted Tue 17 Mar 09 @ 8:56 pm
Well in most cases depending on the the Wifi cards of the machine they are known to create latency issues and therefore the pops, crackles, and/or degraded sound performance. This goes for Bluetooth as well. Specially if the connection is just sitting idle and not actively passing data like when broadcasting.
If the issue stops when you turn off the Wifi then I would think you have found the underlining problem.
geposted Tue 17 Mar 09 @ 10:01 pm
any suggestions on how to fix this problem
or any troubleshooting I coud do
geposted Tue 17 Mar 09 @ 10:12 pm
Run this useful tool
http://www.thesycon.de/deu/latency_check.shtml
Basically, any red spikes and you have latency problems.
geposted Wed 18 Mar 09 @ 1:15 am
Hiya,
Ive jsut got a new pc and also had this similiar problem !...I discovered it was my "energy saving" feature (not sure if your pc has 1) on the new mother board I have !!! ..as soon as I turned it off no more skips/cliks in sound !!!
May b usefull for anyone else having sound issues !!!
CB
CB
geposted Wed 18 Mar 09 @ 8:23 am
