Hi, not sure if this topic has been dealt with before. (I could not find it)
I (sometimes) use the iTunes playlist functionality to load songs to the decks. Some of the songs contain non-standard symbols like for example a german "ringel s". For some reason VDJ will not load these songs, which requires me to modify the song data in iTunes to "standard" symbols. Not a major problem, but I wonder if this is a known issue with VDJ or if there is something wrong with my settings. (I'm in the 20-day trial period of PRO)
Note, that in iTunes I have no problems whatsoever, so it really has to do with VDJ.
(Other than this minor issue this is an extremely easy to use program, seems very stable and is good fun ! )
Thanks
HM
Thanks
HM
geposted Tue 17 Mar 09 @ 5:55 am
It is a known problem.
VirtualDJ can't read certain or strange characters in the Tag/file names. Thats why you are experiencing problems. I've had one or two I've had to change.
geposted Tue 17 Mar 09 @ 1:19 pm
Ok thanks !
geposted Tue 17 Mar 09 @ 2:52 pm
