When I start virtual dj I go to the sound card settings. I see that my sound card is active, but when I try to use a different port the music cuts off and only comes out of that one. Basically I have two outputs but if I put anything in the head phones output it doesn't come out the rest of the computer. Is there anyway I could use just one output for head phones?
geposted Wed 18 Mar 09 @ 1:59 pm
Which Hercules device do you own and which version of the software do you use?
Could you also please let us know your spec?
geposted Sun 22 Mar 09 @ 7:33 am
I am using a Hercules MP3 with virtual dj 3.4
I figured out my problem, I simply needed another soundcard.
geposted Wed 01 Apr 09 @ 9:39 pm
