so im at the bar on my regular night...
and when i plugged my headphones to the rmx instead of hearing just the cued song, i hear whatever is playing in the other deck, no matter if its only on the deck i want to cue, its throwin me off, since i they are at the same level and well with my monitor ride beside me i think ill be deaf, anyways wondering if anyone has any clue of whats goin on, the option in the rmx n vdj where i choose if i want to listen to the cue or the mix is on the cue one so i dunno whats up...any ideas?
geposted Fri 20 Mar 09 @ 8:54 pm
sounds like you have accidently moved the cue control, top right hand corner of rmx next to headphone volume control
geposted Sat 21 Mar 09 @ 6:52 am
hi guys,i´m having a prob with headphone on midi mixer,i use 2 tccd,sl1box & djm700.
My problem is::::with midi on when you move the fader all the way down on real mixer,it means that on vdj´s mixer the fader will be all the way down as well,and with the faders all the way down on vdj´s mixer,you cannot have sound coming from the real mixer,do you?i also made a small video explaining what´s going on,sorry about the video quality,made with my cellphone.
http://www.youtube.com/watch?v=0uhGxniv_Fw
geposted Sat 21 Mar 09 @ 5:57 pm
thanks for replying tayla, doesnt seem to be like that though, i have double checked options features everythin is just the way it normally is n the way i normally check on things, uhm....
any other ideas?
djnands...get ur own post please
any other ideas?
geposted Sun 22 Mar 09 @ 1:34 am
check sound setup in confiq...
geposted Sun 22 Mar 09 @ 1:47 am
Input: none
Output:headphones
and running the ASIO Driver thats how its always been
Output:headphones
geposted Sun 22 Mar 09 @ 4:55 pm
these are my settings
input: none
output: headphones
sound card(s): rmx
apply eq: not ticked
output channels: master: chan 1&2/ headphones: chan 3&4
in options tab > auto headphones: always
in rmx
audio mode > wdm (high lighted green)
input: none
output: headphones
sound card(s): rmx
in rmx
geposted Sun 22 Mar 09 @ 7:44 pm
can someone help me please?
geposted Mon 23 Mar 09 @ 2:01 pm
yes on ur own thread
tayla i tried changing it to ur settings n i still get the same thing, this is weird its never done it bfore :/
geposted Mon 23 Mar 09 @ 10:14 pm
any chance of some screen shots of your settings, starting to get me annoyed now as well... lol
geposted Tue 24 Mar 09 @ 5:52 am
i should be able to get some, but not at the moment
but ill post them up asap
geposted Tue 24 Mar 09 @ 6:09 am
ok mate, this has got me baffled, probably the solution is staring us straight in the face, so if anyone else can chip in please do....
geposted Tue 24 Mar 09 @ 7:47 am
are you using the maya 44??i had this problem with the maya 44...
geposted Tue 24 Mar 09 @ 8:02 am
i think he is just using the rmx as soundcard
geposted Tue 24 Mar 09 @ 8:10 am
If you are using the internal mixer you cannot use an an external que monitor effectlively
you will need to get your quing from your sound card.... or just use your mixer as anonlog and assign the xfader for the videos
since you do not use it.
Thanks,
DJ SMG!
geposted Tue 24 Mar 09 @ 4:57 pm
yes the rmx is being used as the soundcard
geposted Tue 24 Mar 09 @ 5:19 pm
hi hazord,thx for trying to help,i think that the problem is because the main sound comes from vdj´s levels"Faders" and not from vdj´s gain).because if using cd player plugged into mixer,when the fader is down i can still have sound on the headphones,because it comes from gain. on vdj´s mixer it comes from fader,not from vdj´s gain,is there anyway to change it in vdj?and thx again for tryng to help bro,
geposted Wed 25 Mar 09 @ 3:58 pm
djnands
man would uplease stop invading my thread yes this forum is helpful and all but get ur own! everytime i come back thinkin someone replied to mine it is a reply to ur post wtf??
be respectful n get ur own
geposted Thu 26 Mar 09 @ 11:47 am
psichomanti23,ok man sorry
geposted Fri 27 Mar 09 @ 6:17 am
hey tayla so i got a new thing for you regarding this issue, when i was hookin up everything for anothr gig, i discovered that if the master volume is all down, then i only hear whatever is on cue....problem is for everythin to work great obviously master volumen should be up, n this is when i get whatever is playing.....plus the cue! :/ ....right now ive managed to go through with settings being on outputs 1 &2 being the master and 3&4 being the headphones, but it sounds too distorded (spl?) , i still cant get where this began since its never happened before
anyone else out there that might have a clue? PLEASE?
geposted Tue 31 Mar 09 @ 10:31 am
