hey guys im gonna format my hd soon
i wanted to know, once i reload everything, will cue re reconize all the songs and how they were corrected in the data base?
or i need to re do all that?
or is there a file i can save that will re establish how the data base is written
what i mean is that lets say a song is named 123456.mp3
but in reality its a song called help.mp3
i corrected that in the cue program for cue to reconize it as help
hope u understand what i mean
thanks!
thanks!
geposted Sat 21 Mar 09 @ 1:38 pm
You will need to back up your database files VirtualDJ Database V5.xml
If you are just formatting your pc harddrive - just back the one up here: MyDocumers/VirtualDJ/.....
If you are fomartting an external drive then the databse file will be at the root of the drive.
If you simply put these back on the formatted hard drive everything should be fine. ;)
geposted Sat 21 Mar 09 @ 3:32 pm
Thank you
geposted Sat 21 Mar 09 @ 3:42 pm
