Hello;
when using automix, everytime a new song starts I get a sound like "beeep" or something like that for a second or fraction of it.
I've tried different laptops, different soundcards (idjio, SL1), etc. I cant imagine what else to try.
Now I'm using a Gateway laptop, 2.26 mhz, 4 ram, 1 g. dedicated video.Numark total control. (64 bit vista), but before I had the problem with XP (32 bit) also.
everything else works perfect.
Please help.
Thanks
Ian
Please help.
Thanks
Ian
geposted Mon 23 Mar 09 @ 6:21 pm
Never heard of this b4, can u record on VDJ and post a link. May figure it out if I hear it
geposted Mon 23 Mar 09 @ 11:05 pm
I'll do it, meanwhile i tried with another card, gigaport ag, same issue, when in automix, as soon as a new video starts a sound is heard (beep, or something like that). if I change everything to simplest mode and hear the mix from the headphone output of the laptop it doesn't happens. Also it doesn't happens if the track is mp3 (only music). If I click the option "ultra latency asio" instead of the beep i get a fraction of second stop of the sound.
Help please.
Thanks
Help please.
Thanks
geposted Tue 24 Mar 09 @ 9:54 pm
Hi
Its known issue as I know so far no fix and problem is known already for year at least. Im waiting also for fix so I can finally buy vdj.
See following thread:
https://virtualdj.com/forums/83000/PC_Version_Technical_Support/Automix_Problem.html?search=automix+video+problem&page=2
geposted Mon 27 Apr 09 @ 11:48 am
What mix setting do you have?
Do you mix the videos together in the automix? Or do you play out one video to the very end, then start next video at the very beginning?
geposted Mon 27 Apr 09 @ 4:53 pm
