Ok, hi guys I have a Macbook with virtual DJ version 5.2 and I love it.
So I wanted a few extra audio effects and I had read that VST effects work with Virtual DJ so I wanted to use a plugin called "crayon filter", it's just a filter. This plugin has the extention .vst and all the ones in the audio effects have 2 files, .bundle and .plist. It seems that there's a problem because it doesn't work.
Is there any way I can use VST effects with Virtual DJ?
Thanks
Thanks
geposted Tue 24 Mar 09 @ 4:47 pm
Please register your serial number mate and i will look into the problem.
geposted Tue 24 Mar 09 @ 5:37 pm
