Don't know if it would make a difference but wouldn't the quality of the timecode be better in a higher quality mp3 file i mean 128 is crap against the quality of 320kps mp3s just a thought i don't know .
geposted Tue 24 Mar 09 @ 7:55 pm
Huh? does it matter? its a timeCODE. Its like morse code with font size 12 and 300, does that matter?
geposted Tue 24 Mar 09 @ 10:13 pm
The timecode is controlling the software its not for listening.
geposted Wed 25 Mar 09 @ 12:22 am
It doesn't matter what size bitrate the time code is. The time code sound is only a command to play. That has nothing to do with the quality of the sound output. If you want to hear your music good, you have to have good mp3s at a higher bitrate. Your source is your music files. If you have crappy music files, you will hear it crappy.
geposted Wed 25 Mar 09 @ 1:00 am
You all don't understand the question. 128 kbps sound quality sucks and might cause some change in the sound too.
But the opinion is correct: although 128kbps is a bad quality, timecode signal is basically only one monotone note played troughout the entire cd, so 128kbps in enough for this purpose. As for your other music: stick to minimum 192 :)
geposted Wed 25 Mar 09 @ 11:03 am
We know the question.... Changing the time code bitrate wont make his MP3s sound better. Like i expained before, your music bitrate is the source to good or bad output. That makes a difference. Not the timecode.
geposted Wed 25 Mar 09 @ 5:27 pm
That's not the question: he's talking about the timecode mp3 file that can be downloaded on this site, and which is only 128kbps. If it's in a higher quality it might affect the timecode quality. It's not about the sound output.
geposted Thu 26 Mar 09 @ 10:29 am
im having problems with my tcv
geposted Mon 30 Mar 09 @ 4:51 pm
