I just got a ibook g4 with a 1.33ghz processer, and 512 ram.I plan on adding a 1 gig ram stick.Will this be enough to run vdj using just audio with my xponent?I'll be using the ibook strictly for djing.Also someone told me I should get a firewire hard drive because it will load faster.Is this true? Thanks alot
geposted Wed 25 Mar 09 @ 7:53 pm
Yes and no. Despite USB2 is faster in theory (480Mb/s) than Firewire (400Mb/s), in reality Firewire is still faster. However, that does not mean that all external Firewire-hard drives are faster than the internal hard drive in your iBook. Smaller laptops usually use 2.5" 5400rpm hard drives, just like most of the smaller external hard drives. So basicly the speed advantage of using an external hard drive is negligible unless it has a 7200rpm (or faster) disk inside it.
geposted Thu 26 Mar 09 @ 5:06 am
So will the laptop cut it once I upgrade the memory?Before i buy vdj
geposted Thu 26 Mar 09 @ 9:27 am
Hi feelhim,
This are the recommended system requirement on mac.
Mac OSX 10.4.7 or higher
Mac/Intel Core Duo 2.0 GHz or higher
1 GB RAM of higher
200 MB free on the hard-driver
Minimum system requirements on mac.
Mac OSX 10.4 or higher
G4 1.5 GHz or Intel Core Duo 1.6GHz
512MB RAM
Regards;)
1 GB RAM of higher
512MB RAM
Regards;)
geposted Fri 27 Mar 09 @ 8:46 am
Also sometimes when im mixing the volume will go down a little and sometimes I'll get distortion.Would that be the hardware or the software?thanks
geposted Sat 28 Mar 09 @ 1:39 am
As u may be aware there are no mac trial atm. So using unofficial product may have that effect. If u do have already purchase VDJ, pls do register in ur profile and upgrade to the recent version v5.2.1 if u have not done so;)
geposted Sat 28 Mar 09 @ 4:55 am
Did The Mixtrack Pro work OK with your ibook G4?
geposted Tue 23 Aug 11 @ 4:32 pm
This thread is back from march 2009!
The Mixtrack Pro "MINIMUM COMPUTER REQUIREMENTS" are
Windows:
Intel Pentium 4 or AMD Athlon XP
1024x768 SVGA video
512MB RAM (1GB Recommended)
CD drive
USB port
20MB free on the hard drive
Macintosh:
Intel processor
Mac OS X v10.5
1024MB RAM
CD drive
USB port
30MB free on the hard drive
http://www.numark.com/mixtrackpro
closed Please don't bump an old topic that is over 2 year old.
Please open a own thread if you have further questions :-)
Windows:
1024x768 SVGA video
CD drive
USB port
Macintosh:
Intel processor
Mac OS X v10.5
1024MB RAM
CD drive
USB port
geposted Wed 24 Aug 11 @ 5:26 am
