I downloaded the new version for Vista install_virtualdj_djc_v3.4.1.exe, after installing I try to run and it only say:
"VirtualDj will now try to connect to the internet and check if a new version is available"
"you can disable this in the CONFIG menu at any time"
Then i get an error:
"DirectX sound driver error"
Nothing else happens VirtualDJ does not open at all.
I also have the Hercules insatall:
Package: 4.HDJS.2008
Firmware: 1.3.6.15
Driver: 4.3.0,0
DJ API: 2.0.16.6
CPL: 2.0.3.1
Any idea on what can i do
thanks
Firmware: 1.3.6.15
Driver: 4.3.0,0
DJ API: 2.0.16.6
CPL: 2.0.3.1
thanks
geposted Sat 28 Mar 09 @ 1:44 pm
That is not the correct version - try downloading the trial version from this website...
geposted Sat 28 Mar 09 @ 2:09 pm
