check out this amazing software: http://www.kroll-software.de/products/mp3db_e.asp
supports my external 1tb usb hdd with 185,119 songs.
FREEWARE.
sql database.
multiple sql queries (filters with help)
multi tag editor
multi file support
this is such an awesome software for editing tags
filtering files out, and then filtering out more files.
select multiple files, and edit them all at once.
My name is dj shahar, and i've never seeen such an efficeint tag editor in all my life.
and the best part: it's free.
go there, dl the software, and tell me what you think.
FREEWARE.
sql database.
multi tag editor
multi file support
geposted Sat 28 Mar 09 @ 7:09 pm
Nice find.
Just DL'd and installed.
It will take me a while to tryout all the features, but it looks very complete.
Thanks
geposted Sat 28 Mar 09 @ 8:58 pm
it's very complete.
you can even drag songs from mp3db 2008 to virtual dj same as you would form virtual dj its self.
i just wish someone would finally built a music database with use of sequel instead of access.
geposted Sun 29 Mar 09 @ 12:13 am
