Hello everyone, my external HD is not being recognized. Also, VDJ just crashed on me. Here is the crash report:
sh ID=76a3e12d (date=903291507, version=5.2.1 Pro, build=521, thread=Main, dump=81792820, excode=c0000006 (0,29e0028))
Freeze (date=903291507, version=5.2.1 Pro, build=521, thread=Screen)
Crash ID=76a3e12d (date=903291507, version=5.2.1 Pro, build=521, thread=Main, dump=81792820, excode=c0000006 (0,2840028))
I rebooted my laptop and VDJ detected the HD, it shows the floders and songs names but when I load a song, nothing appears on the VDJ decks. No wave patterns, song name and artist name. I rebooted my laptop and VDJ crashed. And my HD is not being recognized. I need help.
Syberman
Syberman
geposted Sun 29 Mar 09 @ 2:26 pm
I would plug that drive into another compter first.
Does the software function with other media sources?
geposted Sun 29 Mar 09 @ 2:31 pm
I plugged my HD to my desktop and Windows gives me a error message that it does not recognize it. I have all my songs on there. Please tell me that I can recover this.
Syberman
geposted Sun 29 Mar 09 @ 2:50 pm
Well I can't tell you that.
I trust you hear and feel it spin up and see indicator lights preferrably green and not red.
You should seek the advice of a data recovery company.
If its making noise, it could be too late.
Drives are cheap guys, no reason to play roulette with our libraries.
I change mine every 2 years and they become my latest back up instantly.
Good luck with this.
geposted Sun 29 Mar 09 @ 2:55 pm
Yep,
Rash mate, it's sounds like your drive is starting to fail.
geposted Sun 29 Mar 09 @ 3:02 pm
Just wanted to update, After numerous rebooting, everything works. I have no clue on what happened. I had a gig last night and everything was running the way it should be. I don't know what went wrong but everything is up and running. I did not loose my music, thank God! I am going to buy 2 external HD's. Man, that was a close call.
Syberman
Syberman
geposted Sun 29 Mar 09 @ 4:07 pm
Syberman
Syberman
While your buying...get extra cables too. It is an easy fix in some situations....
geposted Sun 29 Mar 09 @ 4:13 pm
Yes, your right. I will. Thanks for the advice.
Syberman
Syberman
geposted Sun 29 Mar 09 @ 4:40 pm
Syberman
Syberman
They are external crashes. Especially in windows dll.
geposted Sun 29 Mar 09 @ 6:02 pm
DjCel, what does external crashes mean? Pardon my ignorance.
Syberman
Syberman
geposted Sun 29 Mar 09 @ 7:08 pm
In short an external crash is something else other than VDJ causing it to crash..
For example: VDJ may crash because of a problem with a piece of hardware or the operating system.
geposted Mon 30 Mar 09 @ 5:46 am
Got it. I understand now. Thanks all for your help.
Syberman
Syberman
geposted Mon 30 Mar 09 @ 1:35 pm
