Hi, I am a newbie to the Virtual DJ Forum, so hopefully I am complying with etiquette!
I have previously worked on a computer which had VirtualDJ Version 3.0 installed and I have got used to working with both 'decks' available for the automix facility.
After recently buying the VDJ Home Edition for my own laptop I found that this newer software uses only one deck for automix.
Would a replacement 'skin' for my version 5 software give me the same automix setup as in version 3.0?
If anyone can assist here I'd be very grateful :)
Thanks for your time and attention,
Ian.
Ian.
geposted Mon 30 Mar 09 @ 11:21 am
You can't.
This feature doesn't depends on the only skin. If you do not like that, you should re-install the old version.
geposted Mon 30 Mar 09 @ 2:32 pm
No, the auto mix was changed in v5 to a single deck system. It will not be changed back any time soon to my knowledge.....
geposted Tue 31 Mar 09 @ 5:42 pm
