hello i bought hercules console rmx today and it had the virtual 5.0 djc and when i press the serial number on the profile it says this serial code already registered
geposted Tue 31 Mar 09 @ 5:28 pm
Where did u buy it from??
geposted Tue 31 Mar 09 @ 6:04 pm
to a shop close to me it wasnt open when i bought m8
geposted Tue 31 Mar 09 @ 6:08 pm
actually first of all i am having problems cause i dont know how to assing samples or effects that i have on 1-6 buttons left and right i use normaly the 5.2.1 pro but to assign the buttons i need to use the one that i got with the console and it doesnt have the samples and the effects that i have and i cant even put them in it has no bank or anything i can only drag songs..... help me on all .... especially on serial so i can dl the new skin for console that has sample effect bank
geposted Tue 31 Mar 09 @ 6:14 pm
You might want to bring the RMX back, and ask for one where the software has not been licensed.
geposted Tue 31 Mar 09 @ 6:18 pm
is there any way that i can assiqn the buttons with virtualdj:internal mixer skin?
geposted Tue 31 Mar 09 @ 6:23 pm
Nope, there is a skin you can use, but you need to input your serial to get it. Hercules RMX & Steel Skin
When you become a valid user, there is also a plug in you can download that will help. RMX Config Plug-in.
Also, the RMX version should have a defult skin with it. I am not sure if you can change those 6+6 buttons.
Practice & Enjoy!!
DJ Digital
Practice & Enjoy!!
DJ Digital
geposted Wed 01 Apr 09 @ 9:28 am
