Question gang...
Is it possible to map the crossfader to a button (NOTE) on the vci100? What I would like to do is just 1 button to crossfade back and forth? Is this possible using 1 button? If so how? I have tried playing with the settings and I can't even get it to go all the way over? If I hit the button it only goes to the left (from deck 2 to deck 1) if I have the value at -127 and this is with momentairly unchecked.
If I have to use 2 buttons (one for from deck 1 to deck 2 and vice versa) what would be those values?
Thanks a bunch.
Thanks a bunch.
geposted Thu 02 Apr 09 @ 11:53 pm
Left would be 0
Right would be 4096
Right would be 4096
geposted Fri 03 Apr 09 @ 2:41 am
Thanks Brian. I'll give that a try this evening.
I'm guessing that I have to use 2 buttons to pull this off instead of one button doing it all?
geposted Fri 03 Apr 09 @ 9:48 am
you could use the shortcut "crossfade hamster" in the system area. this reverses the crosfader with every press
hope that is a bit more on the lines of what your after
geposted Fri 03 Apr 09 @ 6:16 pm
hmmm neither seem to do what I'm after. the one brian suggested cut/abrupt. I'd like to hit the button like on the dmc2 where it performs a smooth transition going from deck 1 to deck 2 and vice versa.
geposted Sat 04 Apr 09 @ 9:51 pm
OOOHHHH hang on a min, I will find it for you...
geposted Sat 04 Apr 09 @ 10:20 pm
U are looking for Auto_crossfade. This is for both Audio and Video.
You can set it with 2 buttons Ie left arrow and right arrow and it will smoothly crossfade.
geposted Sat 04 Apr 09 @ 10:21 pm
You can do just the vid with Video_Trans
geposted Sat 04 Apr 09 @ 10:26 pm
videotrans! ahh. I remember seeing that somewhere but must have missed it when I went to look for it again. Yes just for video not audio.
Thanks Brian..will let you know if it works.
geposted Sun 05 Apr 09 @ 3:17 pm
