Is it possible to setup two midi devices under General Midi?
I'd like to be able to control effects with a Trigger Finger and then control the video crossfader with the Pioneer DJM-800 audio crossfader. Is this possible or am I taking crazy pills?
Additionally - is there a cable that has two midi outputs going into one USB? So that I could have the Trigger Finger & DJM-800 going through the same cable (to save USB ports, basically).
geposted Mon 06 Apr 09 @ 3:21 am
I think you can:
General MIDI should recognize both of the two controllers like one but with different CTRL signals.
geposted Mon 06 Apr 09 @ 6:32 am
It is possible but will depend on what midi notes/signals each device sends.
The problem will arise if the same note is sent by both devices.
geposted Mon 06 Apr 09 @ 6:37 am
Can you expand on that?
geposted Mon 06 Apr 09 @ 10:23 am
